leaky 700
Old Sep 15, 2002 | 03:48 PM
gmc4life's Avatar
just got an 2002 sportsman 700 hundred and after inspecting it, i found gas dripping from the bottom of the gas tank. anybody else have this problem if you did, how'd you fix it?
Old Sep 15, 2002 | 04:19 PM
SpruceDuece's Avatar
Where is it leaking? I have heard of some leaking where the foil wrapped lines connect to the tank. Some dealers have replaced the tank. Mine is not leaking.
Spruce Deuce
Old Sep 15, 2002 | 05:03 PM
mtpockets's Avatar
gas leak?
bring that baby right back to your dealer and demand to know who did the PDI inspection......than tell the owner to FIRE him!
-MT
Old Sep 15, 2002 | 05:34 PM
PolarisMech's Avatar
they should fire the engineer who designed it.
all ya need to do is take the hose fittings out of tank, and put some teflon tape on the threads,and reinstall.
Old Sep 15, 2002 | 11:35 PM
sheremji's Avatar
I had this problem on my '99 Sportsman 500. Removed the lines and taped the threads with teflon. Also supported the circumference of the threaded insert with epoxy. No issues since in over 2 years. Fuel line are a little wobbly were they go into the tank as it is metal tapped into plastic.
BruteForce57
TheATVSuperStore
Apr 1, 2015 10:33 AM
kendogu
Mar 2, 2015 10:07 AM
fooey
ATC 3-Wheelers
Dec 25, 2007 10:15 PM
MarkL
May 22, 2006 01:01 PM
yrrej
Jun 16, 2005 06:55 PM
