Synchronizing carbs
Old Sep 15, 2002 | 09:15 PM
Oshawa's Avatar
As the title might suggest.How do I go about synchronizing my carbs? I had read something before about using vacume gauges on each carb and adjusting "something" until they both have the same reading.
Any help would be appreciated.
R.
Old Sep 16, 2002 | 05:22 AM
Haynes1111's Avatar
I used the Carbtune II this weekend. It was an easy chore. Check it out at http://www.carbtune.com/
Old Sep 16, 2002 | 09:09 AM
Surveyor's Avatar
Oshawa,
on the right side of the quad, you'll have to get doen low to see it, there are 2 capped off ports on the intakes, one on each, take the caps off, and put a line to a carbtune/mercury stick/vacum guage..
then there is a screw that is between the carbs that controls the butterflys..(on the left side of the quad) if you have access to a manual, it is on page 2-11) this is what you adjust, you want to get the carbs equal or specs is within 2 cm of each other..make sure the quad is warmed up good before checking/adjusting, & if you adjust, blip the throttle & check it again..
hope this helps..
Old Sep 16, 2002 | 09:50 AM
monteSS's Avatar
So you can use just a vaccum gauge that checks on at a time. Of coarse it will take longer but it can be done then.
Old Sep 16, 2002 | 11:53 AM
trx450's Avatar
I used to sync. muti-carb set-ups on cars by listening to the "hiss" of each each carb's intake. Do you have a manual? It'll show you what others are explaining here, about which screw(s) to adj. Just remember to do small changes, and wait a few seconds for the change to take effect.
Old Sep 16, 2002 | 03:31 PM
MJSTX's Avatar
Oshawa: Royal Distributing sells a multi carb sych. tool, I have seen it in thier snomachine catalogue. If you want more info. let me know.........MJSTX
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
