winch mounting
Old Mar 24, 2000 | 08:59 PM
markshop's Avatar
My dealer must have been out of polaris mounting brackets and winches when i bought my sp500, because i noticed the winch said warn built exclusively for yamaha. My question is the mounting bracket is only mounted by 3 bolts on each side. 2 right through the top frame and the other 1 through where the rack mounts in front.The winch is upside down. The bracket is on top. My question is do you guys think this is mounted strong enough?
Old Mar 25, 2000 | 06:45 AM
rkelman's Avatar
Having trouble visualizing what your saying but I count 6 bolts.. Sounds strong to me Just a note. Just because the winch itself says Yamaha on it. Dont make the assumption the mounting bracket is Yamaha. It'll be the same as any other Warn winch maybe the bracket is Polaris..
Old Mar 25, 2000 | 08:44 AM
markshop's Avatar
Well to make it easer to understand the flat plate of the bracket where the winch ackually mounts is up against the bottom of the plastic rack and the winch hangs under it. The 3rd bolt only goes through behind the plastic rack. So when you pull on it its only pulling on plastic. So really it only has 4 bolts that are secure through the frame. The bracket does not go down the sides of the radiator support at all.
Old Mar 25, 2000 | 05:00 PM
BigCatDriver's Avatar
On my Y2K 500 ArcticCat the A2500 Warn is attached to the fram with only 4 bolts and trust me it is a solid mount, I have pulled many a person for some unfortunate surrounding and the winch has even pulled my into them. The mount is awsome, ArcticCat tyhought ahead because the winch is protected by a 3/8" steel plate that protects it and does not affect the approach angle. Yamaha on the box dont worry!! Why would a Polaris Dealer have Yamaha equip.
chuck
2000 ArcticCat 500 4x4, Warn A2500, and soon to have 27" 'Vamps
Old Mar 25, 2000 | 08:35 PM
markshop's Avatar
My dealer sells polaris,yamaha,honda,and kawasaki
Old Mar 26, 2000 | 08:53 AM
rkelman's Avatar
Have a look at this web page it shows a picture of a real polaris winch mount.http://www.polarisindustries.com/pro...gc=3&gg=15&g=7
Old Mar 26, 2000 | 07:20 PM
markshop's Avatar
Looks nothing like what they put on mine. Mine doesnt go down the sides of the radiator mount at all.Just straight back to the top frame.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
