'02 Rubicon Shift Sensor Failures
Old Sep 18, 2002 | 09:19 PM
swampdonkeykiller's Avatar
Has anyone experienced transmission shift sensor failures? I have three buddies who have all had this problem. All before they got 100 hrs on their machines. One of them has had this problem happen three times already and he doesn't even have 150 hrs on it yet.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Sep 22, 2002 | 01:37 PM
This is a pretty lame website if noone is willing to share basic Information that would be of some help to people.I am sure someone out there has heard of this problem and A reply would be appreciated.
Old Sep 22, 2002 | 08:36 PM
RUBICONJOE's Avatar
Hey, I HAVE A 02 RUBI 1800+ MILES, MY FRIEND HAS OVER 8,000 ON HIS 01 NO SHIFTING PROBLEMS, DISCRIBE MORE OF WHAT THE PROBLEM IS
Old Sep 23, 2002 | 03:49 PM
The problem is the shift sensor on the left hand side of the transmission/engine housing under the exhaust is crapping out. It locks the transmission in whatever gear it feels like and cuts out reverse. You can't select any gears manually nor can you use D1 or D2. It doesn't reset itself when you turn off the key for a while eitheir. Once you change out the sensor with a new one, its good to go. The first time my buddies brought their three machines in, there was at least 9 other ones with the same problem at the dealer already.
Old Sep 23, 2002 | 09:30 PM
RUBICONJOE's Avatar
START IT UP, LET IT RUN 5 MINUTES.......
BEFORE YOU TURN IT OFF PULL FORWARD 8FT, THEN BACK UP ( make sure your on level ground )...
* MAKE SURE WITH KEY OFF ITS IN NEUTRAL ON ESP
* ON THE LEFT CONTROL HOLD BOTH UP AND DOWN SHIFT BUTTONS IN AND TURN THE KEY ON
* YOUR LCD DISPLAY WILL FLASH ( - - )
* AT THIS TIME RELEASE UP AND DOWN SHIFT BUTTONS ( youll have to do this fast )
* PUSH UP....DOWN....UP.....
* YOUL HEAR THE TRANSMISSION MAKE SOME NOISE
* THEN PUSH THE THROTTLE WIDE OPEN THEN LET GO..........
YOUR LCD SCREEN SHOULD RETURN TO NORMAL.........
THAT SHOULD FIX IT
Old Sep 24, 2002 | 03:56 PM
Thanks for the tip. I will tell my buddies about this and maybe give it a whirl if it happens again!!
Old Sep 24, 2002 | 07:53 PM
YZGUY's Avatar
My foot has never had any of these problems. Something to be said in favor of simplicity here, I think!!
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 15, 2015 02:45 PM
