do you really need to jet if you pipe and filter
Old Sep 24, 2002 | 03:43 PM
gatron777's Avatar
Got kvf650 and want to get pipe the big gun is out in my area now and want a little more power,is jetting nessesary? read a few stories about bikes missing a bit and backfire after they had jet them.also heard if you didnt jet you could fowl your plugs.need some help,like to do it all at once if needed.and if so is dynojets #132f and #136r the proper ones?
Old Sep 24, 2002 | 04:01 PM
NovaKaw650's Avatar
If you don't jet for the added flow you won't gain much and might even lose a little. I've got a Supertrapp IDS-X with 9 discs; the Dyno Jet recommendations were close. I ended up one step leaner than their recommended starting points for the mains and needle jets. You live in Dartmouth; Freedom Cycle in Bayers Lake had a new machine set up with a Big Gun pipe. They told me that they put in the DJ kit at the recommended starting point and it worked good. You might want to talk to them. Also, do a search on the forum for this topic.
Old Sep 24, 2002 | 04:13 PM
gatron777's Avatar
Thanks Scott im going to freedom cycle tomorrow and take it for a spin i just got off the phone with them.Thats where im getting the pipe and i was on the forums earlier but i noticed alot of mixed reviews.Thanks again.
Old Sep 24, 2002 | 04:23 PM
NovaKaw650's Avatar
Ask about EPI clutch springs while you're at it. The black driven spring gives a good gain for little cost. I don't know if Freedom carries them, though.
Old Sep 24, 2002 | 04:30 PM
gatron777's Avatar
I will check into it thanks scott.
Old Sep 24, 2002 | 09:46 PM
stebob's Avatar
To answer your question, YES, you will need to jet if you put a pipe and high flow filter on. If you don't you will be running the machine lean. This will destroy your engine eventually.
Old Sep 24, 2002 | 11:43 PM
gatron777's Avatar
Getting that bad boy some jets for sure now thanks for the reply.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Sep 25, 2002 | 12:43 AM
alltoys's Avatar
Gatron777 No, you do not have to jet up this is a false hood anyone who tells you this is nuts. When you install a better muffler you will increase power by almost 10% right off the top. The manufacturer shipped the bike out somewhat rich to start with. The muffler modd will lean out the system. All you have to do is adjust your airscrews to get proper fuel to air mixture. The new muffler as would the same modding the muffler via Nyrocs specs, increases flow from intake to exhaust. By increaseing the flow you can experiment to gain more power by yes installing larger jets. By no means do you have to imediately go with larger jets and I have proven this on a dyno. I have posted in the past the results of these tests, just for a recap you will depending on temperature and elevation get these results.
This is at 2200ft you can expect slight differences as elevation increases or decreases at least 9.35% with the muffler alone. I use the Kawi Jets 145fr & 148r another 1.25% this is after the muffler. Before I touched the carbs I modded the muffler adjusted the airscrews and it ran fine no problems. Before you touch the carbs get a Diamond G Snorkle this with some larger jets will be your next modd for sure. If you can put in as much volume as you get out you will have a very efficient motor. Have fun!
Old Sep 25, 2002 | 10:04 AM
gatron777's Avatar
thanks, i used to have a honda 350x and put a bills pipe on it and never had problems even with plugs and that was running champion plugs lol but true and had it for 6 years but didnt know how it could effect newer bikes and ther not f###ing cheap any more.definitly not a mechanic back yard at best.
Old Sep 25, 2002 | 10:34 AM
NovaKaw650's Avatar
My 650 was lean from the factory here at sea level. I rode in Vermont for 2 weeks in July at 2000 - 3000 ft. above sea level and the machine was stronger in the thinner air. This was before I had made any mods - bone stock. As Alltoys posted, try the pipe w/o any jetting changes and see how it works. I'm also running a Twin Air filter and 5 one inch holes in the air box cover. With the IDS-X pipe, filter and air box mod, my machine basically wouldn't run when I tried it with the stock jetting. Maybe your's will be different.
