PLEASE HELP ME FIGURE OUT WARRIOR PROBLEM
Old Sep 24, 2002 | 06:45 PM
crankase's Avatar
I NEED HELP with a warrior problem.I just finished putting together a 98 warrior i got cheap that some guy i know crashed when it was only 6 months old,he never fixed it and just bought a new one.I got it for 500.00 but it was stripped,plastics,tires ,ect. ect.Thats all finished. It will run perfect untill you really get on it then it cuts out like its in a rev limiter,when you let off a little bit its fine,i checked the timing,tried rejetting,4 or 5 times,[that got it running] i even took my daughters carb off her perfect running warrior and it did the same thing.It has around 100 hours on it tops.I cant figure it out.TELL ME SOMETHING GUYS,i just spend all weekend tring to figure it out,NEXT STEP, the yammi dealer,then that will be the end of my [GOOD DEAL] THANKS IN ADVANCE
2000 ds 650, 2-98 warriors
Old Sep 24, 2002 | 07:39 PM
osrider's Avatar
I'm not for sure, but it might be the emergency brake. look by the emergency brake there's a black piece that inserts into something. it might be loose. I just took mine out tapped it up real good and put it back under it.it makes it cut out when you give it the gas and it hardly runs.i did that and it fixed it but that might not be your problem but hopefully it is cause it's an easy fix. hope that helps.good luck
Old Sep 25, 2002 | 12:06 AM
95wolv's Avatar
The parking brake switch should only affect it right off idle,it was meant to prevent brake frying from leaving the parking brake on,but if it shorts out intermittantly,it could cause problems. If it was in a crash,it could have knocked the stator out of alignment,I had a similar problem with my Wolverine when new,a bad skip on the top end. It turned out the gap on the stator to the firing coil was too wide,this will cause 'spark scatter' at high rpm,the gap makes a weaker spark,so when you really need it at the top end, you loose power to the plug,and it misses and skips. Have the dealer or whoever your mechanic is check the gap to the firing coil to see if that is the problem. Hope that helps you out. By swapping carbs(very good troubleshooting!!) you have eliminated the fuel side as a source of the problem.
Old Sep 26, 2002 | 01:02 PM
EasterEgg's Avatar
There is a ground wire attached where the reverse selector is. If this connection gets corroded it will skip at high rpm`s. Remove and make sure you have a good connection. I had to do this at least once a year on my 92 Warrior. HTH
Old Sep 27, 2002 | 03:03 PM
jay660Raptor's Avatar
I just bought a 03 raptor. 1st day out in the pits - thing hits a limiter like it was in reverse. Nuetral, in gear, in reverse did the same friggin' thing. Finally got pissed, pulled the sensors off the reverse sensor. No good. Pulled the E-brake sensor off - ran perfect. How about that , brand new & it F'd up.
SO if you guys hit a rev limiter problem on a raptor - yank the sensor off the parking brake.
Damn yamaha's.
Old Sep 27, 2002 | 03:41 PM
chad400ex's Avatar
Yep, definitely check the ground wire at the reverse selector. That is a very common problem. If it is loose or has a bad connection, the warrior won't run worth a damn.
Old Sep 29, 2002 | 09:03 PM
QUADZZUKI's Avatar
It could be the ground wire, but if u have an aftermarket pipe and airbox mods then Im betting that its due to ur valve springs. U need heavy duty springs on a Warrior because the stock springs arent strong enough to close the valves all the way with ur new found power. My buddy had this problem 2 years ago and there was an article in Dirt Wheels about this a few months back.
Old Sep 29, 2002 | 10:04 PM
95wolv's Avatar
Quadzuki has a valid point, I forgot about the springs on a stock Warrior will float at sustained high rpm, would definately cause cutting out on the top end. Putting new springs in is not a minor job,but you probably could if you are mechanically inclined.
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Captjay
Jul 23, 2015 12:33 PM
steveo612
Jul 11, 2015 08:35 AM
Albertascramblerx
Jul 8, 2015 11:56 PM
