650 stalling
Old Sep 29, 2002 | 11:36 PM
gtchief's Avatar
If I'm riding for a while and then stop on the trail(to wait for others) my 650 will sometimes stall out on me. It starts right back up with no trouble, but its a pain that it stalls out. Should I just turn up idle? And what way on it is up? One other thing; is it normal for my fan to run 2 minutes or so after turning it off? Thanks alot guys, this forum is great.
Old Sep 29, 2002 | 11:42 PM
cardiovascular's Avatar
It is O.K. for the fan to run several minutes after stopping. It just needs to cool off a little. Most of the different makes and models will do that especially on the bigger bikes. As far as the stalling there have been some problems with the choke cable being too short on the 650 so if this is the case it may be choking itself out. hope this helps
Old Sep 30, 2002 | 08:30 AM
trx450's Avatar
gtchief--- the idle should be set at 1100 rpm HOT. Is it? Check the gas tank vents, if idle is in spec.
My 650 goes thru it's little fan cycle, too. On a hot day,when I shut it down, the fan will run @3 min., turn off for 2-3 min., then come back on for 2 min. I recognize it as normal now!
How are those new tires???????????
Old Sep 30, 2002 | 09:31 AM
gtchief's Avatar
I love the tires TRX. They look great and perform great, I still have a pretty smooth ride too. How can I check what my idle speed is? Thanks
Old Sep 30, 2002 | 09:54 AM
MDG's Avatar
MDG
There was a service bulletin on the choke cable. The dealer should replace it for free. I don’t know if the new cable has new springs at the carbs, but you need to make sure those are replaced with the new longer springs. I know the new spring part numbers were posted on here somewhere. They might be on NYROC's site. The new springs fixed my stalling problem and returned some power that I didn’t even realize that I had lost. Good Luck
Old Sep 30, 2002 | 12:19 PM
trx450's Avatar
gtchief--- Know any mechanics? They should have a inductive tachometer that you could use.
Glad you like the tires. I'll try the 489's up frt next time I need tires.
Old Sep 30, 2002 | 02:19 PM
MrB's Avatar
MrB
Have you had it serviced by the dealer could be carbs need synchroed and adjusted
thats what they say anyhow
I just got mine and Im curious what you may have already done[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Sep 30, 2002 | 02:24 PM
MrB's Avatar
MrB
Have you had it in to the dealer to have carbs synchronized,adjusted and rejetted for youre altitude you ride in
I just purchased mine and Im curious what you may have already done to try and solve the problem
Old Sep 30, 2002 | 03:25 PM
trx450's Avatar
MrB--- We share the same motto(almost): "Momentum is your buddy", is mine. Ain't it the truth, when climbing a gnarly hill!!!!!!
Old Sep 30, 2002 | 09:04 PM
gtchief's Avatar
I dont think its the choke, but I'm gonna stop by my dealers on thursday and ask him if it is the right one. I got it in march, wasnt this problem already fixed by then? Thanks guys
