425 Magnum Speed
Old Oct 1, 2002 | 05:33 PM
SuzukiQuadrunner160F's Avatar
What is the top speed of a 1996 425 magnum 2x4?
What are some good mods?
With a pipe and clutch kit could it beat a sportsman 500HO in a drag?
Old Oct 1, 2002 | 08:23 PM
MuDsLiCa's Avatar
a stock magnum 425 and a stock sportsman400 run the same... i topped out my sp400 at 58mph on a gps. with the modifications you get, you will definately feel in increase in speed, but i dont think youll be able to beat a sp500 in a drag. My sp500 beats the sp400 by about 9 to 11 lenghts, and my sp700 beats the sp500 by about 10 lenghts.
Old Oct 1, 2002 | 08:57 PM
ok then thanks for the info but what clutch kit & Pipe would you recomend what about a K&N Air filter. Is there any other add ons that you can put on to make it look better?
Old Oct 1, 2002 | 08:58 PM
O and i love the way my magnum sounds it just howls will a pipe change that sound.
Old Oct 1, 2002 | 09:26 PM
ftwflh's Avatar
I dont know how fast my 425 is by MPH but it will hold its own with my 400 2 stroke and with the 500s.I have it set up with a SupertrappIDS2 pipe,K&N filter,white polaris primary spring,blue Aaen secondary spring,a 145 main jet in the carb.When you go to modifing thing it breaks other things so be forwarned when you up the power you stand a better chance of breaking parts.
Old Oct 1, 2002 | 10:42 PM
Just the other day i burried the needle on mine going down the road. So thats over 60mph on a polaris speedo.
Old Oct 1, 2002 | 11:34 PM
ftwflh's Avatar
You cant believe a speedometer on a quad or a bike.Need to use a GPS.When I had speedoss on mine it show around 55 on the magnum and burried on the Sportsman.
Old Oct 2, 2002 | 11:59 AM
I found another one is $3500 Canadian good for a 1996 425 magnum 2x4 with 1900 miles.
is that a good price.
Old Oct 2, 2002 | 12:11 PM
ttaylor's Avatar
FTWFTH,
How do you like your 96 magnum 425 4X4? How do you like the Chain drive to the front diff? I am looking at the exact machine but wanted someones opinion on how good these are and how well the 4X4 system holds up.
