Need some kind of adapter
Old Oct 10, 2002 | 11:03 AM
jtrundle's Avatar
Default Need some kind of adapter
I have a 97 scrambler 400 4x4 with a Mikuni 38mm TMX Carb. with a K&N air filter (air box removed). Winter is coming and I need to put the factory air-box back on to keep snow/water and such out. My problem is, the factory air box won't fit on carb intake. Is there any kind of adapter made for this I can buy somewhere?
Old Oct 10, 2002 | 02:58 PM
jtrundle's Avatar
bump.
Old Oct 10, 2002 | 05:31 PM
JoshCVBz's Avatar
Hmmmmm....mine had a 42mm carb and fit. The problem that I had was on the other end of the carb.
Sorry I can't help.
-Josh
Old Oct 10, 2002 | 05:49 PM
CED's Avatar
CED
Give HPD or Ritter Cycle a call because when i received my 39 pwk carb it came with an aluminum adapter on the air filter side that would fit the air box.The adapter was pressed in the carb.Hope this helps.
Old Oct 11, 2002 | 12:26 AM
modquad's Avatar
HPD now mills the inlet down. Maybe call Hot Seat, since they're the ones that sell the 38. I know the 42 I bought from them had an adapter on it.....then again, they probably mill their's too...hehe..
You could also just get a water resistant Outerwear filter cover, they really work nice.
Ken
Old Oct 11, 2002 | 10:01 AM
BubaHyde's Avatar
My 99 with AAEN kit is running a 42mm carb
It has an adapter to use the stock air box. They also sell the 38mm carb.
I am sure if you call AAEN they will set you up with what you need.
Old Oct 11, 2002 | 03:56 PM
jtrundle's Avatar
Thanks CED!!!
franklyme
Oct 21, 2016 07:18 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
