primary clutch flex
Old Oct 11, 2002 | 07:41 AM
sbatzold's Avatar
Default primary clutch flex
Any one have their clutch cover off and notice how much the primary pulls it self towards the secondary when in nuetral and you engage the clutch?
Old Oct 11, 2002 | 09:42 AM
Bubba297's Avatar
Yes, and they will all do it, and more so under throttle when in gear. The drawback is that you lose belt deflection and alignment, which robs power and performance. Dennis Shotwell sells a torque strap to help the problem ddjshotwell@qwest.net They cost about $45. another thing is to put the harder race mounts in it. That will keep everything correct and the power where it should be, to the trans.Bubba
Old Oct 11, 2002 | 10:02 AM
500DUSE's Avatar
YOooo Bubba,
Can you tell me anymore about the torque strap?
Proes,cons,website?
Old Oct 11, 2002 | 11:32 AM
Bubba297's Avatar
Most use it for the race modded stuff since thay usually engage at a high rpm and put alot of initial torque on the motor. It definitely would be a benefit for the 4x4's and anyone putting their machines under a load. It basically mounts to the front of the recoil housing and has a snubber to rest slightly against the frame. It helps control motor vibration too. E-mail Dennis at that address and tell him to e-mail you his flyer. It is a single page of a few things mostly for the race bikes, but has the torque strap on it and the contact info. I dont see any cons on any setup for the strap. Hope this helps,Bubba
Old Oct 11, 2002 | 10:25 PM
2manytoys's Avatar
You can change the motor mounts to race mounts and this will take care 90% of the flex.
Old Oct 13, 2002 | 01:37 PM
500DUSE's Avatar
Thanks guys
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
