Help with breakin time?
Old Oct 16, 2002 | 12:25 PM
Babyzillalt250r's Avatar
Default Help with breakin time?
I'm getting ready to replace my rings , can anyone tell me the average breakin time and how to go about breaking it in for just ring replacement ? Thanks in advance , Drew
Old Oct 19, 2002 | 09:19 PM
2fun's Avatar
Well, I'm assuming you got the cylinder honed at least.
Hopefully the piston still has lots of life in it too?
One tank of gas should be good enough to break in the new rings.
I would just follow the method for breaking in a new engine.
Vary the RPM's, and give it gobs of gas.
Go though all of the gears under load too.
You want to generate enough heat to "seat" the rings to the cylinder.
I do not have direct experience with just breaking in a set of rings, so I am only ASSUMING that you would follow the normal engine break-in pricedure which also has a lot to do with properly breaking in the piston too (heat cycles).
Anyone else care to elaborate more??
Old Oct 23, 2002 | 10:28 AM
ZigZilla's Avatar
Ok here you go ...check these links on breakin time.....this is all the help you need.
Trinity 2 stroke break in instructions
Trinity 4 stroke break in instrutions
Old Oct 23, 2002 | 04:05 PM
2fun's Avatar
Right, but that is for a fresh PISTON and rings.
I am not sure if the heat cycles are necessary for just RING break in or not.
I could be wrong, but I believe that the heat cycles are for the expansion and contraction of the piston, as it will expand and contract more while it is fresh?????
Old Oct 23, 2002 | 09:21 PM
ZigZilla's Avatar
It wouldnt hurt to be safe. [img]i/expressions/face-icon-small-cool.gif[/img]
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
