Will a stock Trailblazer 250 do a wheelie ?
Yup, I have seen it done but I have never done it. However I believe that you will have to hold the front brakes to get the RPM's up and then dump in and pull back like a ****.
-Josh
-Josh
It is hard for a stock Trailblazer to do a wheelie but you can do 1 of 2 things to make it wheelie easy. You can put a 90 dollar clutch kit from HPD or buy a 18 dollar white primary spring from polaris. If you plan on doing any more mods then go with the kit. If not then the spring will do . Either on of these will make you wheelie all day long.
Grab the brakes and give it gas until the back end rises up to the end of the shock then turn it loose and pull up.
