MORE PERFORMANCE
Old Mar 31, 2000 | 08:35 PM
ATC250R!!'s Avatar
I HAVE A 1984 ATC250R AND AM FEELING THE NEED FOR MORE SPEED I NEED HELP TO GO FASTER.MY MODS ARE AS FOLLOWS
BORED 30 OVER
PORTED AND POLISHED
K&N FILTER
DG PIPE
DG SILENCER
ANY HELP WILL BE APRECIETED
Old Mar 31, 2000 | 09:36 PM
hondatrx300ex's Avatar
you might a get a fmf ram valve or something like that. later
Old Apr 1, 2000 | 02:09 AM
CT250R's Avatar
Are you still running the stock carb? If so you will probably see a big gain since it has already been ported and piped up. A different reed cage as well as a reed spacer will finish it off nicely. If this is still not enough try running alcohol. I think the '84s were air cooled? If so then alcohol would definetely be they way to go to help keep it cool also. Alcohol really wakes up blasters. I have seen one on it with a 240 kit that would run with a mildly done Banshee (pipes,porting non big bore stock carbs).
CT250R
Old Apr 1, 2000 | 01:24 PM
Blazer250's Avatar
My friend has a 350 big bore kit on his ATC250R. It's pretty fast. It will run with banshee's up Sand Mountain, Utah. He wheelies up the whole mountain!
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
