Balancing tires?
Old Nov 5, 2002 | 12:08 AM
RebelDS's Avatar
Default Balancing tires?
I have ITP 589's on my 650 and at around 30 or 35, it's kind of hopping on the front in, like the tires are out of balance. Any way of balancing ATV tires and rims?
Old Nov 5, 2002 | 12:17 AM
partsman2's Avatar
When I bought my Bearclaws I had the local tire shop mount them for me. I told them I wanted them balanced and they looked at me like I was goofy. I said hell boys the thing runs 65 MPH and it does make a difference. After a 1/2 a$$ attemped to mount them on the balancer he said he couldn't do it so I told him to forget it. I haven't had a problem though. Make sure you don't have any mud caked in one of your rims. I would think if you took it to a motorcycle shop that handles a lot of tires they would have a balancer.
Old Nov 8, 2002 | 05:30 AM
Dickieboy's Avatar
I had the same problem with the ITP 589's. First, I set the toe-in to zero, but didn't help much. Finally balanced the front wheels and the problem with wobble was solved. One wheel took 14 oz. I glued the flat weights to the inside of the rim and coated the whole thing with Goop. I've had them on there for a few months without any problems.
Old Nov 8, 2002 | 07:14 AM
nyroc's Avatar
I got one of those cheap bubble balancers from JC whitney (or northern tool) and the stick on weights. It works very well to get rid of the wobble. The tire stores I went to could not balance my wheels due to the larger center hole in the rims.
However, I did not use goop to hold the weights on, and some of the weights got knocked off by a stick because I did not use goop.
Old Nov 8, 2002 | 07:25 AM
trx450's Avatar
I would agree with partsman2, the first mudhole you hit, they go out of balance from the mud that usually collects on the inside bead. I never worried too much about it. Let's face it, you don't spend much time on the 45-65 MPH envelope anyway! That is, if you ride the woods much.
Just my 2 cents worth.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
