Rubicon dip stick
Old Nov 14, 2002 | 01:41 PM
hondabige's Avatar
Default Rubicon dip stick
Does anyone know how to read this thing for sure?
Old Nov 14, 2002 | 03:53 PM
RubiconBob's Avatar
While sitting on a flat surface, start and let run (idle) for 5 minutes, then shut off. Wait about a minute, then pull dipstick, wipe it off, and stick it back in hole BUT DO NOT SCREW IT BACK IN. Pull it back off, and the oil level should be between the 2 marks. If it is, you are OK. If it is low, or very close to the lower mark, then add some in to bring it somewhere in the middle to top half of the marks.
Screwing the dipstick in will cause an inaccurate reading, as will checking it without letting it idle. Letting it idle makes sure that the oil is pumping through the motor and transmission (remember, they share the oil), and that it hasn't all drained back into the reservoir while sitting overnight. Also, don't make the mistake of taking out the dipstick or oil fill cap while the motor is still running! Don't ask, and I won't tell....
shimanok2
Jan 29, 2016 07:37 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
