LT250R Crankshaft & Crankcase Question
I need to install my crankshaft from a 87 LT250R in the left crankcase and my book said you needed a special tool to do this correctly. I called my dealer to get a price and he told me all I need to do was heat up the case with a heat gun and the crankshaft would slide right into place. Have anybody heard of this? I have heard of this for replacing seals and bearings. Also is it strange that the crankshaft came out of the case without any special tool? It slid right out. The crank is fine I just split the case to clean it out because it had a piston blow. The shaft appears to go right back into place, and I have now been told this is fine, but I wanted to check with you Suzuki guys. Any info on this would be great.
Thanks
Thanks
Thanks....This forum is so much better then any of the other ATV sites I've posted questions on. You guys actually take the time to answer questions and help!!! Motor is back together and everything seems smooth.....now lets up it fires up.
Thanks again,
Dave
Thanks again,
Dave
If it came out with no force then it should go back in no problem. I think a heat gun might be a little hot, what I normally do is turn the case upside down with a light bulb under it for an hour or so. I also put my crank in the freezer for a day because mine is very tight. But you don't have to do that since it came out so easily. Good luck
