DS Axle Bearing went out. Is this common.
Old Nov 27, 2002 | 06:27 PM
DSONYX99's Avatar
Default DS Axle Bearing went out. Is this common.
I did a search for anybody else who had an axle bearing go out, and I couldn't find any. Has anyone else had this go out? I know how to fix it, but this just seems kind of strange.
Thanks for the input.
Old Nov 27, 2002 | 10:02 PM
clif's Avatar
DSONY99, My DS rear axle bearings went out at weally low hours to.It was really dry,and I don think they factory greased it very well.I dont know how many people have had that problems,but I dont think very many.
Old Nov 28, 2002 | 12:01 AM
lilnotts's Avatar
i purchased my used in july, n like 2 weeks later my axle bearings went out (wat a great way 2 start out with a new quad eh?), since bombardier didn't put a grease fitting they can only last so long, especially if you ride in mud n water,
Old Nov 28, 2002 | 12:56 PM
StevieD's Avatar
the bearings on the EX just went out a few weeks ago. like the bomb, there is no grease fitting, and there was barely any grease in the housing. there was some rust in there too. the bearings were completely ruined.
if their was a grease zerk so you could fill it up, i doubt there would be so much of a problem.
Old Nov 28, 2002 | 03:30 PM
Wannaride's Avatar
Guys,
From what I hear it was only a problem with model year 2000 and 2001. They seem to retified it for 2002. Add you own grease fitting when you change your bearing.
Old Nov 28, 2002 | 05:09 PM
BillDS650's Avatar
http://www.nbsdistributing.com/ RAD makes one with a grease zerk for $249.95
Old Nov 28, 2002 | 05:22 PM
kehale's Avatar
My axle nut was loose from the factory. This could have easily contributed to a quick demise of the bearings (had I left it that way).
-T
Old Nov 28, 2002 | 09:44 PM
lilnotts's Avatar
i don't think you can put one on, i looked at how the chain tightener built in the axle carrier, and if you drill through one spot then if you tightened the chain the hole wouldn't line up n e more so no grease would get threw, this is just how it looked 2 me but i could b wrong
STLyamwar
Jul 25, 2020 04:44 AM
austinwhitton
Aug 11, 2015 06:21 PM
toonces
Aug 5, 2015 05:55 PM
black_thunder
Jul 28, 2015 11:05 PM
toonces
Jul 28, 2015 01:58 PM
