What carb for a 310r
Old Dec 2, 2002 | 01:40 PM
Trx440's Avatar
Default What carb for a 310r
I'm building a 250r w/a 310 and was wondering what is the best carb-reed-cage combo to go with and what compression piston [the lower the better so it runs on pump gas] to run if you want the most bottom and mid? I am looking for woods power even though I will be using it in the dunes and desert. I am trying to build a bike that is VERY reliable as this is my "back-up / friend loaner". What do U guys think?
Old Dec 2, 2002 | 06:05 PM
boogerbub's Avatar
For low to mid power you want to go with the smaller carbs- 36mm, and pretty much any of them are good. If you can jet fairly well I'd say go with the air stryker. If you want mid to top, go for a 38-39mm carb.
Stock reed cage with stiff valves (Boyseen) = low to mid
After market reed cage with lots of flow (V-force delta) = mid to top
Not sure about compression. Exhaust-- Shorty silencer= mid to top
Long silencer= low to mid
Actual pipes-- depends on the manufacturer, I here the Eddie Sanders trx 5 is a good all around pipe.
Good luck, and enjoy the R. They truely are the best quads ever made.
Old Dec 3, 2002 | 11:55 AM
Mike330R's Avatar
I had a 38AS on my 310 and it was great. Plenty of low end (from the big bore) and good top.
It's a great all around carb.
Old Dec 4, 2002 | 02:18 AM
Trx440's Avatar
Thanks Booger and Mike. Mike, what kind of piston and compression were you running? Thanks in advance. -RT
Old Dec 4, 2002 | 05:23 PM
airtimehocutt's Avatar
if your using a pro-x cylinder, stock compression is 160lbs.
to run straight premiun gas i would think 140lbs of compression.
they recommend mixing 50/50 racing gas and premium unleaded with 160lbs compression.
i switch between a 38 air striker and a 39 pwk. i cain't really tell a difference between the two (other than the 38as is less prone to studdering over the whoop sections.
for low end power, it's hard to beat a rad vavle. i've switched to a sparks cr250 reed cage and it does not have the bottom of the rad vavle (more mid range hit and upper rpm power, but still a good amount of bottom)
the best bottom end power i have ever had was with the rad vavles and fmf fatty pipe. it was like a tractor but you had to short shift it because the power fell off quickly.
the sparks mx pipe and cr250 reed cage is faster with out a doubt, but doesn't have the down low instant power of the fatty pipe and rad vavles. hope this helps
Old Dec 4, 2002 | 05:29 PM
Mike330R's Avatar
I think it was a Weisco piston and I was over 200 pounds of compression. I ran 100% race gas.
Old Dec 4, 2002 | 09:39 PM
briansgi's Avatar
I've got a ESR 310 with a 9 port, AirStryker 38mm with Delta v-force reeds, ESR 5 pipe and silencer. Quad is perfect, runs flawless, great power mid-top. Great combo!
Old Dec 5, 2002 | 01:52 AM
Trx440's Avatar
Is that '71 Challenger in your photos yours? That is the nicest Mopar I have ever seen.
Does anybody know what carb comes stock on a '85 250r atc?
Old Dec 5, 2002 | 08:57 AM
briansgi's Avatar
Yes, the 71 Challenger is mine along with the '70 Cuda. The Cuda is all original, original 440 6pak motor. The Challenger was originally a 318 car so it's had a "conversion" done on it, I also put a 440 6pak motor in it.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
