650 COUGHING AT LOW SPEED
Old Dec 4, 2002 | 10:46 PM
GILTYLER's Avatar
Default 650 COUGHING AT LOW SPEED
Hi
My 650 has a problem at low rpm. It seems to be poping back into the air box at slow speed.
If you are at mid to full throttle it seems ok. it has 8 hours and i just left it with the dealer.
They said they would have to call Kawasaki to check it out. Any ideas.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Dec 4, 2002 | 10:57 PM
HORSEMAN's Avatar
mine does the same when cold but seems to go away after it warms up. The popping or coughing is pretty loud.
Old Dec 4, 2002 | 11:12 PM
partsman2's Avatar
Mine does it too but only in cold temps. I think it's caused by a lean condition? Any one else got any ideas?
Old Dec 4, 2002 | 11:25 PM
jefffoxsr's Avatar
Do a search about "pilot screws" in this forum. Follow my instructions to adjust your pilot fuel screws and you will be all set.
Old Dec 5, 2002 | 08:25 AM
NovaKaw650's Avatar
The idle circuit is lean. Adjust the pilot screws to between 2 1/2 to 3 1/2 turns out, going a 1/4 turn at a time, and the coughing will be reduced.
Old Dec 5, 2002 | 08:41 PM
TeamGrnMojave269's Avatar
my 360 does it when the motor is cold when i hit the gas before it has had time to warm up.
Old Dec 6, 2002 | 12:38 PM
trx450's Avatar
Adjust the pilots richer.
Old Dec 6, 2002 | 04:00 PM
gregsims's Avatar
Jasonb had the same problem with his 650. He has a few hundred miles on it that were easy trail miles. He had his vavles adjusted and the spitting stopped. I am not contradicting what these other guys are telling you, I am just telling you what fixed Jasonb's 650. It is easy enough to adjust the carb and see, but if that does not fix it, you might just want to try adjusting the valves.
Old Dec 6, 2002 | 08:01 PM
RockyQuarry's Avatar
Ditto on valve adjustment. The job is not much fun, access is tight and you have to bend and cut your leaf guage to get an accurate measurement. I adjusted my vavles at 1100 mi. six were a tat tight. Ran and started noticeably better.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
ReconBayou
Sep 23, 2015 02:41 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
