Best tool for adjusting suspension???
I have a shock adjuster thingey but it does NOT fit well on the rear shock to adjust it? What is the best WAY to adjust them and the best tool?
I tried to get in the rear but it does NOT seem like I can get a good solid grip on the shock from any angle..
Just reach both hands in there and turn as you compress the spring.
I hate those damn knuckle busting, no workin, sorry a$$ tools.
It takes a bit of strength,,,but works the best.
(I assume you are refering to the type found on a stock 400ex)
take all the weight off it first or you'll just be fighting the thing,rear shock needs lube spray to adjust by hand.
I agree with jeffroe but add that you can turn the adjuster nut by turning the whole spring. Its alot easier then trying to turn just the nut. Just grab the spring and turn either direction. Loosten the jam nut with the hammer and screwdriver first though.
LOL
That's eactly what I did, I sprayed it, then hit with a hammer and driver. Then I was able to turn it by hand. I did jack up the back first, but then found I was still able to turn it by hand with tension on it.. Guess I had enough LUBE! LOL
Thanks,, I am under control..
