Best tool for adjusting suspension???
Old Dec 9, 2002 | 01:16 AM
MudStud's Avatar
Default Best tool for adjusting suspension???
I have a shock adjuster thingey but it does NOT fit well on the rear shock to adjust it? What is the best WAY to adjust them and the best tool?
I tried to get in the rear but it does NOT seem like I can get a good solid grip on the shock from any angle..
Old Dec 9, 2002 | 02:15 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Just reach both hands in there and turn as you compress the spring.
I hate those damn knuckle busting, no workin, sorry a$$ tools.
It takes a bit of strength,,,but works the best.
(I assume you are refering to the type found on a stock 400ex)
Old Dec 9, 2002 | 09:15 AM
02BAJA's Avatar
A big screwdriver and a hammer. Use it to tap on the collar at the top. Works like a charm.
Old Dec 9, 2002 | 04:06 PM
MudStud's Avatar
Ya know, I totally forgot about the hammer idea! I did that on my wifes cause I could not get in there!! DUH!! LOL.. Thanks
Old Dec 9, 2002 | 04:24 PM
StevieD's Avatar
the adjuster works great for me. the thing that kills me is that it was like 20$! its just 2 pieces of steel welded together!
Old Dec 9, 2002 | 04:25 PM
StevieD's Avatar
oops...i meant rivited...not welded
Old Dec 9, 2002 | 08:15 PM
JEFFROE's Avatar
take all the weight off it first or you'll just be fighting the thing,rear shock needs lube spray to adjust by hand.
Old Dec 9, 2002 | 10:51 PM
JSsDS's Avatar
I agree with jeffroe but add that you can turn the adjuster nut by turning the whole spring. Its alot easier then trying to turn just the nut. Just grab the spring and turn either direction. Loosten the jam nut with the hammer and screwdriver first though.
Old Dec 10, 2002 | 12:16 AM
MudStud's Avatar
LOL
That's eactly what I did, I sprayed it, then hit with a hammer and driver. Then I was able to turn it by hand. I did jack up the back first, but then found I was still able to turn it by hand with tension on it.. Guess I had enough LUBE! LOL
Thanks,, I am under control..
caveeagle
Sep 19, 2015 01:20 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
