How Do I Beat A Z400
Old Dec 12, 2002 | 06:54 PM
RossDepanfilis's Avatar
Default How Do I Beat A Z400
I"ve got a 400ex with a E-series S-bend, K&N airfilter, 14 tooth sprocket,
and i want to know what i could get that won't invove drilling or too much money to beat a stock z400
anything you know share, could use any help thanks
Old Dec 12, 2002 | 10:21 PM
BadBoyDS's Avatar
I'll tell you a little trick to beat a Z
GET A BOMBARDIER DS650!
I welcome all competition.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 12, 2002 | 10:48 PM
albaBANSHE's Avatar
NoS! or umm? run different tire and rear sproket size, iam not sure but i think smaller? tires are faster?
Old Dec 13, 2002 | 12:38 AM
wheelinforlife's Avatar
press the gas with the thumb[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 13, 2002 | 07:59 AM
adamsmith's Avatar
How close of a race is it now? If you are close in the first couple of gears a cheap experiment would be putting the 15t front sprocket back on. Also smaller tires with the same gearing is slower. However, smaller tires with higher gearing would help eliminate some unsprung weight and also reduce the load on the motor.
Old Dec 13, 2002 | 08:26 AM
ReconEs02's Avatar
Pop the Z-400s tires?
Old Dec 13, 2002 | 09:41 AM
truckracer's Avatar
Originally posted by: RossDepanfilis
I"ve got a 400ex with a E-series S-bend, K&N airfilter, 14 tooth sprocket, and i want to know what i could get that won't invove drilling or too much money to beat a stock z400anything you know share, could use any help thanks
Are you dragracing or what? If you are drag racing you will have better luck with the stock front sprocket.
What jetting are you running in the carb? Air box cover on or off?
Zillarider02 has a 2002 400ex, stock gearing, E-series Sbend,18 discs, no airbox cover, Uni foam, 160 main jet, clip lowered one notch. I see him outrun a couple Z400's. I helped with the jetting on that bike and I can tell you there is a big difference in the way that engine runs when you get it right. Seat of the pants is very deceptive, we resorted to a stop watch over a fixed distance to find the best combo.
Old Dec 13, 2002 | 04:26 PM
their is one problem with a DS 650
The One you have SUCKSSS!!!
Old Dec 13, 2002 | 05:23 PM
BadBoyDS's Avatar
shaneb is right. If you are draggin aganist a z400, you have to go for the holeshot. The z has a pretty potent top end and if you don't get the holeshot your in trouble.
My other best bet to sticking with the z is to powershift. And some better rear tires!
Old Dec 13, 2002 | 08:26 PM
z400rider2003's Avatar
finda rider that suxs no but um id regear it
