Building Motor
Old Dec 19, 2002 | 10:15 PM
FastYellow650's Avatar
Default Building Motor
I have gotten all my parts in today, and will be putting them in this weekend hopfully, is there any last minute help that you can give me before i dig into it, i will be installing a new piston (12.5 to 1 compression), new cams (webs 109 grind), valve springs, under bucket shims and clutch springs, any help will be nice, this is the first time i have gotten inside of a atv motor, i do have some knowlegde about truck motors and i believe i can do this without much troubles,
thanks
Old Dec 19, 2002 | 11:06 PM
glamisds650's Avatar
don't reuse the flanged nuts for the head. use assembly lube on all moving parts.
Old Dec 19, 2002 | 11:26 PM
i got new ones and the bolts that tvi sells
thanks
Old Dec 20, 2002 | 01:27 AM
SANDMAN430's Avatar
check all your torques if you don't have them i have a manual and can let you know
Old Dec 20, 2002 | 02:32 AM
DuneMe's Avatar
If Sandman isn't available, I have a manual too.
I hear the new head bolts are key. Glad to hear you got those.
Some of your work can be explained well HERE
That thing is going to smoke.
Old Dec 20, 2002 | 09:11 AM
thanks for the help, to get to top dead center the shop manual really doesnt say or show how to get it there, when i pull the valve cover use the front sprocket to rotate the motor over till i get tdc?? then install the bolt that holds the crank in place so that it doesnt move?? is this correct
thanks agian
Old Dec 20, 2002 | 09:12 AM
i have the shop manual so i should be ok on the torques specs,
Old Dec 20, 2002 | 09:21 AM
actually to rotate the motor, use an allen wrench through the little cap thats on the magneto cover. I think it is a 6mm allen wrench.
Old Dec 20, 2002 | 10:20 AM
SANDMAN430's Avatar
i used a smaller allen wrench as i rotated the engine to find top dead center, it will slide into the crank. the only other thing that was of interest was the intake manifold, the middle top screw takes a round end allen to remove. I don't remember what all you are going to do but have the intake and head matched up, mine was awful. good luck
Old Dec 22, 2002 | 03:56 PM
i was going good till i got to the valve train, i dont have the right spring compressor to get them out, hopfully someone at work will have some that will, or ill have to take it somewhere to get it done
