Need help with problem on my Rubicon
Old Dec 27, 2002 | 05:17 PM
4WheelRider's Avatar
Default Need help with problem on my Rubicon
I have a 2001 Honda Rubicon. I ride it in the water some and it has a high pitched whine that sounds like it is coming from the left wheel. I have taken the tire off, wheel off and put in a new seal and cleaned it. It is very dirty inside. When I clean it, it seems to help for a short time but the high pitched noise returns. It only makes this noise when I am moving and it is not affected in any way when I apply brake pressure. Has anyone else experienced this? What have you done to fix it? I expect it is the Rim rubbing against the housing, but I'm not sure.
Old Dec 27, 2002 | 06:15 PM
swampdonkeykiller's Avatar
It sounds like there is a rock inside the drum or a piece of the brake hardware inside the drum is rubbing on the drum. Pull the drum off and look for a shiny wear mark on the drum or on any of the linkage or hardware insde the drum. Check the shoes for rocks imbedded in or around them. Also check for shiny spots on the backing plate to see if it has been rubbing somewhere. I don't know what else it could be except maybe a CV joint but I doubt that it is making the squeeling sound.
Old Dec 31, 2002 | 09:17 PM
muzzy3's Avatar
Did you put grease on the seal that rides against the backing plate? Maybe a wheel bearing.
Old Jan 2, 2003 | 10:12 AM
action450s's Avatar
Wheel Bearing going south...
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
