Warn 3000lb. Winch
Old Dec 27, 2002 | 11:25 PM
trekerx145's Avatar
Default Warn 3000lb. Winch
Wondering if anyone has one of these, and if so do you have a bumper that has a mount for the winch fairlead thart is off set. The reason I ask is that in looking at this winch it looks like the winch fairlead needs to be more in the middle so I am wondering if it would work wit having the fairlead off to the one side like the mount is on the bumper.
Old Dec 27, 2002 | 11:44 PM
dbeck's Avatar
Check out the winch receiver system that Montana Jacks (see their forum here) sells. Once you see it you'll agree its the clear ticket!
Old Dec 29, 2002 | 11:52 PM
Arcosanti's Avatar
I have this winch, do a search of my screenname for posts over the past few weeks relating to mounting this winch on a SP600........
The mounting kit that Polaris sells for the SP600 has the fairlead offset like you mentioned. It actually comes in two pieces, one that goes over the top of the winch, and another that comes up below the winch. Both of them bolt together in front of the winch. You can redrill the mounting holes on the fairlead mount that comes up below the winch to have it centered instead of offset. The piece that comes up over the top of the winch cannot be modified from an offset to center cable.
I was a little concerned about only using the bottom part of the fairlead mount, figuring that they had the two pieces bolted together for extra strength. I was able to use the winch quite a bit this weekend to pull a number of large trees that I was cutting down in the direction that I wanted them to go. I had the winch maxed out putting pressure on the trees, and the fairlead didn't bend on me. Granted, I lined up the winch as straight on as I could, but there was upward and downward pressure on the fairlead, and it held up fine for me.
Oops, I just read your signature and noticed you're running a 500HO. I assume the bumper that you are talking of is the add-on tube bumper or something. If that's the case, I guess I can't help you.
Arcosanti
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
