Giving shift lever a raise
Old Dec 28, 2002 | 11:10 PM
Bombastic's Avatar
Default Giving shift lever a raise
Has anybody been able to raise the shift lever beyond the point where it hits the case? I,ve raised it to this point, but seems just not quite high enough to get a boot under it comfortably. This little problem cotributed to a transmission repair ( bent shifting fork I think) warranty covering this one but I,am thinking a little torching and the proper sware words might bend it the way I want. Any suggestion would be appreciated. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Dec 29, 2002 | 01:37 AM
brad650's Avatar
i wear motocross style boots on my ds and i have no problem. my advice is just put it back in the stock posisition and get use to it. thats what i did, and it works just fine.
Old Dec 29, 2002 | 02:31 AM
MudStud's Avatar
Get smaller feet!
JK
Old Dec 29, 2002 | 02:50 AM
BlackHawk's Avatar
I did a search on the idea of using the 400ex shifter on a DS650 and this was the only thread I found, there may be more if you can find them.
http://forums.atvconnection.com/mess...hreadid=304762
That isn't a lot of information, but perhaps CALDS650 knows more.
Old Dec 29, 2002 | 10:10 AM
SANDMAN430's Avatar
i moved mine up and also noticed that it is rubbing the case, have you thought about removing the shifter and maybe bending it a little?
Old Dec 29, 2002 | 10:20 AM
DSjockey's Avatar
Any body know how the offset of a 400EX shifter compares to the DS's offset? I know they make long shifters for the EX...now that might be nice for these 13's
Old Dec 29, 2002 | 02:36 PM
JSsDS's Avatar
Am I missing something here?? I moved mine up one notch, my boots fit under it easily and it doesn't hit the case. Maybe your shifter is bent in?? just bend it out away from the case just enough to miss it.
If you go with a longer off-set, the shifter will always be in the way. JMO
Old Dec 29, 2002 | 03:07 PM
sand45's Avatar
I did the same as JSsDS and my shifter works great!
Old Dec 29, 2002 | 05:54 PM
Gaskett's Avatar
Same as the two above,.... no problems.
Old Dec 29, 2002 | 11:22 PM
BlackHawk's Avatar
Since no one else has this sort of problem, perhaps Alba customized his shifter before they sold him the machine? I don't remember seeing anything out of the ordinary, however I wasn't looking for it nor was I riding his machine ever.If the lever can be bent without heat (as it sounds that it can be from the posts of others) that would be the best solution since heating the metal will weaken it.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
antiguogrumete
Sep 5, 2015 03:41 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
