re enforcement rings!
OMF Racing will sell them to you, about $25 each. You'll have to find a local welder to weld them onto your current rims though, which will cost extra. If you have the Baja rims and only add the inside rear rings, that will be cheaper than buying a full set of rims. You can buy the inner rings for the fronts, just beware that there is very little clearance between the ring and the brake caliper, so if you get any sort of major dents in the ring you could tear your caliper off or just bust it up. I've got the inside rings on my 2001; I noticed one dent in the ring so I'll pound it out someday. I think I like having the rings better than not having them, but you should know the risks before buying them.
Steeldon
Sep 9, 2015 09:38 AM
