re enforcement rings!
Old Dec 30, 2002 | 01:58 AM
brad650's Avatar
Default re enforcement rings!
where the heck do you buy the re enforcement rings that weld to the stock rims!!! i know someone knows where to get them! the DS that won the baja 2000 had the. thanks!
Old Dec 30, 2002 | 02:09 AM
Bom2000's Avatar
I thought that you can't buy just the rings that you had to buy the rims with the rings on them already......
Old Dec 30, 2002 | 02:16 AM
brad650's Avatar
well where the heck you get them?
Old Dec 30, 2002 | 02:25 AM
BlackHawk's Avatar
OMF Racing will sell them to you, about $25 each. You'll have to find a local welder to weld them onto your current rims though, which will cost extra. If you have the Baja rims and only add the inside rear rings, that will be cheaper than buying a full set of rims. You can buy the inner rings for the fronts, just beware that there is very little clearance between the ring and the brake caliper, so if you get any sort of major dents in the ring you could tear your caliper off or just bust it up. I've got the inside rings on my 2001; I noticed one dent in the ring so I'll pound it out someday. I think I like having the rings better than not having them, but you should know the risks before buying them.
Old Dec 30, 2002 | 02:29 AM
brad650's Avatar
im gonna get some maybe, just on the outside
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
