SP 500 Start switch???
Old Dec 30, 2002 | 04:27 PM
danparkcityut's Avatar
Default SP 500 Start switch???
I traded up from my '00 Magnum 325 4 WD to a SP 500 last Summer. One thing I miss is the start switch (on the left handlebar on the 325). On the 500, I have to start the engine with the key (brake locked in, left hand on the key, right on the throttle... way inconvenient).
Does anyone here know whether there is a kit or some other adapter available to put the start switch where it belongs on my new 500?
By the way, that's the only complaint I have on this new unit, it's awesome!!!
Thanks!
Old Dec 30, 2002 | 05:20 PM
Snowride's Avatar
Never heard about having to lock the brake. My 600, you just turn the key and apply some throttle if needed, no need to hold the brake.
Old Dec 30, 2002 | 05:26 PM
Hmmmmmmmmmmm... My guess is you don't ride in the hills much Snowride, but thanks for the response...
Old Dec 30, 2002 | 05:35 PM
Snowride's Avatar
I thought you meant it would'nt start without holding the brake. If you need to start the engine on an incline why would'nt you just use the foot brake and free up a hand?
Old Dec 30, 2002 | 05:45 PM
Thanks again Snowride, good idea! Still puzzles me though, they screwed up a good thing IMHO.
Old Jan 2, 2003 | 09:25 AM
Lightman02's Avatar
I like the key ignition , most people that I know like it better then the push switch. If you need to keep the break on then lock the parking break, and turn the key. If you have to hold in the throttle to get your quad to start in and idle, then yor carb isn't adjusted right or you need to put the choke on. I have 2002 500 H.O and I never have to throttle it or even choke it in warm or cold weather. I just start it up and let it sit, it idles ruff for 30 seonds and runs smooth just letting it sit for 30 seconds not touching a thing.
tiresharkdbb
Sep 3, 2017 02:06 AM
BEEFKING69
Jun 17, 2015 12:38 AM
wildbill59
Jun 9, 2015 02:28 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
