better master cylinder
Old Dec 31, 2002 | 11:50 AM
JEFFROE's Avatar
Default better master cylinder
my stock master cylinder must be junk? i have replaced the pads (were not worn out) replaced the stock brake hoses w/braided lines, bled lines, used DOT 4 fluid, who makes a good master cylinder to replace the stock set-up?
Old Dec 31, 2002 | 12:09 PM
jeffnrivercity's Avatar
For the front brakes?
I have had problems with air bubbles in the calipers before...
Had to tap them between bleeding,to get the air out
Old Dec 31, 2002 | 12:17 PM
JEFFROE's Avatar
oop's did'nt say for fronts, i bled them befor installing any new parts (alot) and still same soft pull?
Old Dec 31, 2002 | 12:26 PM
JEFFROE,
I know how you feel...
I messed with mine for hours...
bought a vacuum bleeder, etc.
Untill "racedude" came over and we started tapping on the calipers with the end of a big screwdriver,and Wha-la...a little bit of air came out of each..then they came up.
Jeff
Old Dec 31, 2002 | 12:40 PM
Marky,
How did you know?
Were you watching us?
Old Dec 31, 2002 | 01:05 PM
BillDS650's Avatar
http://www.speedbleeder.com/ help me with my bleeding of the brakes will worth the $7.00 per bleeder
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
