better master cylinder
my stock master cylinder must be junk? i have replaced the pads (were not worn out) replaced the stock brake hoses w/braided lines, bled lines, used DOT 4 fluid, who makes a good master cylinder to replace the stock set-up?
JEFFROE,
I know how you feel...
I messed with mine for hours...
bought a vacuum bleeder, etc.
Untill "racedude" came over and we started tapping on the calipers with the end of a big screwdriver,and Wha-la...a little bit of air came out of each..then they came up.
Jeff
Jeff
http://www.speedbleeder.com/ help me with my bleeding of the brakes will worth the $7.00 per bleeder
