warn winch
Old Apr 9, 2000 | 12:27 AM
wov98's Avatar
I have a warn 2000 winch on my 98 wolverine. I do a lot of riding in water (creeks). One day the winch would not work. So I took it apart and found that the seals where gone corrsine I guess. I put it back together useing blue atv gasket sealer then the winch worked fine for a few trips but the winch took on water again. I found a dealer in my area but they do not sale replacement part just a new winch. Has anyone had this problem or have any ideas on a good way to fix the water problem winch
Old Apr 9, 2000 | 02:13 PM
JohnnyB's Avatar
wov98 if you look at Warn's web site (Warn.com) you should be able to find a nearby dealer you has the parts you need. Or better yet call Warn's customer service at 1-800-543-9276 and explain your problem. I am sure that they will help you out. They have gone the extra mile for me. Hope this helps.
John
Old Apr 9, 2000 | 08:50 PM
therock's Avatar
WARN winches do not have seals. They are not advertized as water proof or even resistant. I have had my Warn 2000 (Now upgraded to 2500 on the new Y2Kodiak) since 1994. I have had it under water Many times with out a failure. after almost 6 years of such abuse I decided to take it apart and clean it out before upgrading it to the 2500 for the Kodiak.
What I found was the grease was getting hard. I looked at the motor end and seen no evidence of problems but could see where water did settle and dry. You may need a drain hole.
Anyway I re-lubed mine with Black Moly. A real tacky grease that will not mix with water.
Call or go to this webb site. They are real good people with very good prices. Ask for Roger.
http://www.clemson4wheel.com/
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
