Needs choke to start is that jetting?
Old Jan 10, 2003 | 11:06 AM
MudStud's Avatar
Default Needs choke to start is that jetting?
I recently went to the 190 Dynojet and opend the airbox and put a pipe on and the AF screw is on 3 turns. It needs the choke to start. Does this mean I am too lean and should goto the 195-200??\
It runs good once its going and the choke is off it runs at 1400-1500RPM
Old Jan 10, 2003 | 01:30 PM
KenDS's Avatar
The main jet has nothing to do with starting. Starting is all pilot jet and screw adjustment. Do you need the choke to start it when it is warmed up? If so, your are too lean. You can try unscrewing the mixture screw a little more. If that doesn't help you may need to go up one size on the pilot.
Old Jan 10, 2003 | 07:11 PM
lilnotts's Avatar
mine does that to, but after it warms up its fine, since yours is like that i'm just thinking its winter and its cold,
Old Jan 10, 2003 | 08:12 PM
MudStud's Avatar
Yea, it starts fine when its hot. I will play with the AF screw. I got the service manual so I will try what it say to do..
Old Jan 10, 2003 | 08:54 PM
JSsDS's Avatar
Silly me...All this time I thaught they put that choke there for cold starts....Sheesh what was I thinking?? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 11, 2003 | 01:30 AM
jiminok's Avatar
I just changed my pilot from stock 40 to 47.5 and now starts are much easier...I am not sure this is the perfect pilot but this is what ALBA recommended for my mods...the jet was 2.99 or something like that...under 10 bucks. I knew I was rich from all the black soot on my grab bar.
jim
MudStud's Avatar
I did not have any start problems until I jetted. I never even looked for the choke. Now I can reach it in my sleep
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
chinkapin
Jul 14, 2016 06:58 AM
Spokes
Jun 22, 2015 08:02 AM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
