cylinder psi
Old Jan 12, 2003 | 02:14 AM
Hurycne's Avatar
Default cylinder psi
What is the normal cylinder pressure for the DS?
Old Jan 12, 2003 | 10:40 AM
Majorecho's Avatar
since no one else has replied yet, I'll take a guess of 170-180, don't know for certain because I haven't taken readings off a stock bike, but this should be very close. I'll bring my compression tester to 4SW if you want to check your cylinder.
Old Jan 12, 2003 | 11:48 AM
Hurycne's Avatar
I will be testing today and I have heared that 180 is about right just wanted to make sure. What about with a woods piston?
Old Jan 12, 2003 | 10:14 PM
PUSHINTHELIMIT's Avatar
You probably wont get an accurate reading due to the automatic decompressor.
Old Jan 12, 2003 | 10:34 PM
Hightower's Avatar
disengage the decompressor it, then do a check. Used to be easy on cable-linked kick-starters like the Hondas had (350X), now you gotta pull the head cover. Something to be said for the ways of the old - screw that damn electric start, and reverse too!!
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
