Clutch springs
Old Jan 12, 2003 | 10:12 PM
mojave300ex's Avatar
Default Clutch springs
I have a '93 Trail Boss 250 with stock spring with washers as spacers to make in engauge higher. It has awesom wheelie power but no top-end, what are the stock blue polaris spring rates. I could change it with a stiffer spring and get my top-end back and still have high engaugagement. I'm getting a EPI spring because dennis kirk has them for cheap what color, of what is a good spring rate?
Old Jan 12, 2003 | 10:30 PM
Bubba297's Avatar
Looks like you'll have to go with the plain spring (#7041021) or the purple (#7041132). Both have close to same shift pressure as the blue/green, but quite a bit more engagement.. The purple will have a few more rpms on top, but neither will affect your top end. Bubba
Old Jan 12, 2003 | 10:35 PM
Bubba297's Avatar
Sorry, the plain is rated at 77/123 engage and shift rate, and the purple is 83/136.
Old Jan 13, 2003 | 12:01 AM
what brand of springs are you talking about? thanks
Old Jan 13, 2003 | 12:09 AM
Bubba297's Avatar
Sorry, those are OEM Polaris #'s. But now that you know the specs, you should be able to find a close match in another brand. Keep the second # right in that area or it will affect rpms and speed.
Old Jan 13, 2003 | 01:01 AM
I cross referenced and EPI has close to that. I'll either go with orange or red, probably red I don't want too high of engaugement just enough to wheelie. What about secondary? Thanks for advise, I got my new rings in and I'm now running better than ever.
EPI Spring Load
2 1/2 : 1 1/4
Yellow 95 145
White 75 155
Orange 75 140
Red 35 140
Old Jan 13, 2003 | 08:39 AM
ftwflh's Avatar
I have a red EPI primary and a purple EPI secondary that i would let you have both for $20+ shipping.
Old Jan 13, 2003 | 05:59 PM
I just ordered a Red spring. I would still be intrested in the secondary, I have a white EPI secondary. What will a purple give me?
Old Jan 13, 2003 | 10:59 PM
ftwflh. have you have ran the red spring before? how high does it enguage, enough to wheelie? thanks
Old Jan 14, 2003 | 07:50 AM
ftwflh's Avatar
The red EPI is the same as a Polaris white and it is a good coice for stock machines engagement is a litle higher and it makes you excelerate faster.Dont know if it will make your wheelie but you will like what it does.
