how to remove warning labels
Old Jan 15, 2003 | 09:05 PM
sportsman1's Avatar
Default how to remove warning labels
I know this question has been asked before in the forum but what is the best way of removing the safety labels from the fenders of the atv. I don't want to damage the plastic. Any suggestions would be appreciated.
Old Jan 15, 2003 | 09:28 PM
scooterpred's Avatar
i learned this of this forum take a soft towell soak it with hot water let it set on decall awhile then start on a corner and peel the longer you soak them the better all mine came off easy but one i had tp soak it a litte longer took about 45 mins
Old Jan 15, 2003 | 09:42 PM
bmgm37's Avatar
I removed mine after the first ride at the local car wash. The high pressure blasts them right off with no residue left and no damage to the plastic. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 15, 2003 | 10:17 PM
Mudracer300's Avatar
bmgm37 is right a pressure washer will work great just be careful not to hit you decals it takes those off pretty easy too. lol
Old Jan 15, 2003 | 10:52 PM
okiedude's Avatar
WARNING: DO NOT ATTEMPT TO REMOVE THE LABELS WITH HIGH PRESSURE (WATER) IF YOU HAVE ANY CAMO. The camo WILL come off. I speak from experience.
Old Jan 15, 2003 | 11:57 PM
sportsman1's Avatar
Do you think the pressure washer will remove the labels from a 2001 500HO. I didn't know if the longer they stay on the harder they are to get off. I have washed it at the car wash but I haven't directed the water directly on the safety warnings. I am sure if they do come off there will be a color difference. Does anyone know if there is a wax or some product that will bring some of the color back to match where the labels use to be.
I have plans to buy a 700 in mossy oak. I take it, you don't remove those labels without possibly damaging the mossy oak laminate. Some things are better left alone.
Old Jan 16, 2003 | 12:56 AM
firemedic5586's Avatar
I removed most of the labels from my 03 SP700 Mossy oak with a heat gun, and yes I was very carefull so I wouldn't melt the plastic. I'll have to try the wet towel trick with the couple I didnt get around to removing.
Old Jan 16, 2003 | 02:22 AM
ProXPredator's Avatar
I just did that myself, used the wifes hair dryer and then cleaned up the little adhesive that was left with 3-M Adhesive Remover.
Old Jan 16, 2003 | 03:24 AM
modquad's Avatar
There are some inexpensive heat guns available at your local r/c hobby store. They also work great for changing out the changeable inserts on hockey sticks...GAME ON!!!! [img]i/expressions/face-icon-small-smile.gif[/img]
Ken
Old Jan 16, 2003 | 07:36 AM
500DUSE's Avatar
I also did the Heatgun with no problems.
Wher I could,I applied the heat to the back of the plastic.
but it dident make a difference.
Jeff Roper
Feb 1, 2022 11:48 AM
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
panicmanic
Sep 28, 2015 12:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
