thumb throttle
Old Jan 18, 2003 | 11:00 PM
trifin's Avatar
Default thumb throttle
has any one ever broken their thumb throttle?
i got thrown foward after hitting a deeper(much deeper) than expected mud puddle and broke mine .the dealer had a throttle assembly in stock for about $80. i looked at the yamahas and hondas and their levers are metal. is there a replacement available that will have the plug for the 4wd controls that is made of metal where its not so flimsy?
thanks
Old Jan 19, 2003 | 06:44 PM
Mudracer300's Avatar
did you just brake the throttle part or the whole thing with the switch in it??
if it was just the throttle i would think you could buy just the lever part from somewhere
Old Jan 19, 2003 | 08:09 PM
trifin's Avatar
i asked the dealer if you could buy just the lever itself and aparently its not available that way. the lever is all plastic (lever and stem(which is one piece))and the housing is called etc is all plastic also.
when my knee came up to stop myself from going over the handlebars it clipped the throttle upward and snapped the bottom part of the lever off flush with the etc box.
im going to put a bolt up through the old stem and hole the lever in along with some epoxy.this should make a spare. i was hoping to find a assembly made completely of metal to avoid this in the future. i tried salvaging an assembly off a 600griz but it wasnt close enough to where i would want to bastardize my polaris
the thought occured to me, that if the dealer had one in stock, that someone else had to of broken their lever also and might know a better solution than paying $80 bucks for something that sould have been a $6 dollar fix.
Old Jan 19, 2003 | 09:06 PM
OffRder15's Avatar
My friend broke the throttle lever off of his Honda 300 doing wheelies. He flipped the quad over and snap! His fix?..well, he never fixed it. Its been broken for over a year and just sitting there in his garage.
Old Oct 6, 2004 | 04:41 PM
monsonr4's Avatar
Did U ever find just the throttle lever? I broke mine about the same way & was really discussted when I couldn't find just a lever. I really don't want to spend the 90 bucks for an assemble.
Old Oct 7, 2004 | 12:31 AM
Krank's Avatar
Maybe something you need is here
Ebay- Polaris Throttle
Old Oct 7, 2004 | 11:22 AM
monsonr4's Avatar
Thanks, I saw the 99 assy and it will work on my 03, I still would like to find a metal throttle lever, but not having any luck finding one.
Old Oct 7, 2004 | 08:12 PM
Lukester's Avatar
Trifin,
Go to modquad.com and send them a message to see if they know where to get a metal one.
Lukester
Old Oct 7, 2004 | 08:18 PM
tbsleeper's Avatar
hpd has aluminum ones
Old Oct 7, 2004 | 09:02 PM
texastrails's Avatar
THE SAME THING HAS HAPPENED TO ME. I WAS TO STUBBORN TO PAY THE EIGHTY BUCKS. BEING GOOD WITH METALS,I MADE A THUMB ASSEMBLY IN ABOUT AN HOUR. EIGHTY BUCKS FOR AN HOUR OF MY TIME IS NOT BAD. THE SHAFT HAS TO BE TAPERED,DRILLED,AND SPLINES CUT. BUT THE DEALER SAID IT COULD NOT BE DONE.THAT WAS TWO YEARS AGO. EVERYTHING OK
