no spark on 01' Trailblazer
Old Jan 19, 2003 | 03:51 PM
matts250's Avatar
Default no spark on 01' Trailblazer
hi,
i have an01' trailblazer and i could not get it to spark. I figured it was something in the wiring, so i pulled off all the plastics to inspect the wiring harness. After days of trying to figure out what was wrong i found that one of the wires that came out of the engine had been pinched between the frame and gas tank and grounded on the frame and was a little burnt. a little research and i found that it was the wire from the exiter that signaled the CDI unit when to fire the ignitionn coil. i used the continuity tester and the wire is fine. OK, that said could the wire being grounded have killed the CDI unit?
Thanks
Old Jan 19, 2003 | 03:53 PM
Polaris69's Avatar
did you try the spark plugs?
Old Jan 19, 2003 | 03:58 PM
matts250's Avatar
the plugs fine there is no power to the plug
Old Jan 19, 2003 | 04:00 PM
Polaris69's Avatar
hmm, well i would say theres something wrong with the trailblazer.
Old Jan 19, 2003 | 04:03 PM
Polaris69's Avatar
does it start when you pull start it?
Old Jan 19, 2003 | 04:20 PM
matts250's Avatar
no everything works it turns over fine electric start everthing but the spark
Old Jan 19, 2003 | 08:47 PM
2manytoys's Avatar
Sounds like the CDI to me. Not cheap either.
Old Jan 19, 2003 | 08:50 PM
2manytoys's Avatar
Or the stator.
Old Jan 19, 2003 | 09:37 PM
Conkster's Avatar
Try un pluging the wire that goes to the kill switch and then see if it has spark. Because i have a 99 tb and about a year ago i had the same problem as you when i was ridding it just lost all of its spark.
and it turned out to be the wire that goes to the kill switch had some water between the conectors.
Hope this helps get you going again. By the way its the wire that goes to the kill switch on the handlebar and not the key switch.
Old Jan 20, 2003 | 09:03 PM
matts250's Avatar
no i checked the kill it is fine. the CDI is $157 i guess thats what i got to buy.
thanks everyone
