got a new rear shock today off ebay, its for an 2+ swingarm, will it work??
Hey guys appreciate any info here: the shock is TCS set up for 175 lb rider with 2+ swingarm, my setup is 200 lb rider stock swingarm. mostly to be used in dunes and big air-- like 6 feet so far but gettin higher every time, anyway i figure if i just loosen the preload up a bit, and im 30lbs heavier than the previous owner ill be allright, and since im more into jumpin than racing mx or something, i think the shock will work out well, the vavling will be much improved over stock and the new springs will help prevent bottoming out. What do you guys think,
im going try it and ill tell ya how it goes.
Rob.
Rob.
