300ex sprocket sizes
Old Apr 11, 2000 | 10:47 PM
300exSTER's Avatar
I have a i have a 95 300ex w/ K&N air filter, trail porting, all around valve job, complete gasket set, clutch kit, baja skids, Weisco piston, xct holeshot tires (22-10-9), suppertrapp e pipe and silencer. I want to put a sprocket on it (SIZE 13) so i can gain more low end..the trails i ride on are tight and rough. If i put it on..will there be a substantial difference in low end? Right now, w/ stock gearing i can stick w/ a stock warrior until it hits 6th gear. if the sprcket it put on..will i be able to have alot better acceleration? Thanks guys (i know i will loose top end)
Old Apr 12, 2000 | 12:40 AM
Mike300EX-99's Avatar
Stock gearing on a 300EX is 13/38. Double check and see what your running. I have a 14 tooth on mine, it pulls the gears longer. The front end is a little heavier than with the 13 tooth, it'll still wheelie pretty good though. A little top end is gained how much I don't know. Double check your gearing and let us know how you're doing. Good luck.
Old Apr 12, 2000 | 06:23 PM
ss396's Avatar
Did you have to remove the guard to run the 14 tooth sprocket?
Old Apr 12, 2000 | 06:29 PM
Y2K300EX's Avatar
I have been told that you have to either remove the guard or grind in down until it fits.
Old Apr 13, 2000 | 07:19 AM
Yes you do have to remove it or have it milled down to fit. I'm always checking chain tension and chain and sprocket wear. I run with mine off, but I'm gonna have my case saver worked over and put it back on. Better to have something than nothing at all. I run 20-11-9's on the back and haven't run the 13 with those tires yet. I'm going to try it next time I ride. It should climb hills really well.
Old Apr 13, 2000 | 10:53 PM
300exr's Avatar
mike you ought to put on the 13 tooth sprocket, because i, too, have 20 inch tires and a 13 tooth sprocket. I can pull almost any hill in 3rd gear easy. I have never tried any hills in 4th YET. I just got it a couple of weeks ago.
later
buddieboy
Dec 9, 2016 05:50 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
