Blaster front sproket retainer plate problems
Old Jan 29, 2003 | 03:18 PM
BlueBlaster's Avatar
Default Blaster front sproket retainer plate problems
I was in the middle of replacing both of my sprokets and chain, when I noticed that the front sproket was loose, it was the factory original and both bolt were tight, but you could grab the sproket and wiggle it all around. So before I put the new sproket it on I replaced the retainer plate, because the original one had shown signs of wear, so I thought that was the problem. I put the new one on and you can still wiggle it, but not as much as before. Does anyone know if there is supposed to be play in the front sproket or is it supposed to be tight and not move at all? I would think that it should be tight.
Old Jan 29, 2003 | 04:46 PM
AlkyBurninX's Avatar
All front sprockets that use that plate wiggle. That is why I hate them. The setup does work though and is easier to change the sprocket than on a banshee that uses a large nut.
txkevin
Sep 21, 2015 02:02 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
Shooterj2003
Jun 21, 2015 09:02 PM
gdmclnh
Jun 13, 2015 05:32 PM
hoopduerr
Jun 1, 2015 08:22 PM
