LEAKY WARRIOR
Old Jan 29, 2003 | 07:25 PM
perrya's Avatar
Default LEAKY WARRIOR
I have some oil seeping out of the bottom of my crank case and some leaking out by the front sprocket.
When the motor running in neutral i can see it bubbling out.
Can someone please give me a few hints on how to fix this.
I have noticed a loss in top end power.
Thanks
Old Jan 29, 2003 | 07:41 PM
warrior007's Avatar
If its leaking out of the bottom where the case halves meet you may have to split the cases to fix it. make sure its not just the leak from the sprocket seal which can just be replaced with a new one pretty easy.
I had my factory skid get bumped up against the bottom of my case and it all but rubbed through. I had to take it apart and had a machine shop fix it.
If the oil is bubbling out make sure your breather tube is un-obstructed
Old Jan 29, 2003 | 11:33 PM
pvtCowboy's Avatar
It sounds like your piston rings are worn out and allowing compression into the crankcase. The only way you could have bubbles is if the crankcase was under pressure(a pretty bad thing). If you rebuild the top end *most* of that should stop. It's blowing the oil past the seals....
Old Feb 4, 2003 | 08:31 PM
perrya's Avatar
So all i would have to do is replace the piston rings?
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
