replacing gaskets and washers
Old Jan 30, 2003 | 09:01 PM
whitebread's Avatar
Default replacing gaskets and washers
would you really replace all those gaskets and washers that the manual says to replace when changing tha cam and piston??
Old Jan 30, 2003 | 09:18 PM
BlueLeader's Avatar
you can get the base, head, valvecover, and cam chain tensioner gaskets from your dealer.
Old Jan 30, 2003 | 09:22 PM
whitebread's Avatar
i was probably going to get them,but i was just wondering if it was really necessary?
Old Jan 30, 2003 | 09:23 PM
AdamsBadDS650's Avatar
I replace the head gasket, base gasket, and stuff like that, but I don't replace the copper gaskets for the oil lines, I have also never replaced the o-rings for the timing check caps, valve check inlets, carb boots, etc. I haven't replaced the crush washer on the countershaft sprocket. Usually, the crush washers are positioned where only one tab can be crushed down, so I would just break off the used tab, and position it to where the 2nd tab can be used. That way you can use each washer twice.
Old Jan 30, 2003 | 09:27 PM
whitebread's Avatar
i probably going to replace them all just to make sure its done right.you watch,i'll get all this stuff put back in,get it broke in,and be hauling a$$ in the first race of the season and my tranny will let go. god i hope not!!!
bzdok1234
30
Feb 23, 2016 01:55 PM
SDR-II
Sep 29, 2015 01:06 AM
toonces
Jul 28, 2015 01:58 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
