quaker state 10w-40 peak performance good or bad?
Old Jan 31, 2003 | 10:14 PM
blastnbaja's Avatar
Default quaker state 10w-40 peak performance good or bad?
i just got done w/ my first oil change and choose to go w/ quaker state peak performance 10w-40 motor oil. I chosed this because the only four stroke oil autozone had were synthetic blends. Should I be worried about using this oil? I also changed the oil filter.
Old Jan 31, 2003 | 10:16 PM
buttfungus's Avatar
It should be ok. Alot of us run castrol gtx 10w-40 with no problems. You may want to go with a higher quality oil if you mod your engine.
Old Jan 31, 2003 | 10:22 PM
Raptoryfn660r's Avatar
RIP Dear Friend
I do all kinds of oil blending.
ChetRacer 75/25 oil mix.
Old Jan 31, 2003 | 10:39 PM
jiminok's Avatar
Chet...are you ever serious???[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jan 31, 2003 | 10:47 PM
lilnotts's Avatar
thats wat the dealer told me 2 use and i've had good luck with it, and it not 2 expensive either
Old Jan 31, 2003 | 10:57 PM
RIP Dear Friend
I do blend my own oil in the summer time.
25% synthetic and 75% 10w40 whatever dino oil you like as long as no fiction modifiers. Pour it in the special Chetblendall to mix and into the machine.
My stock 01 Raptor stays slick inside.
I love clean ChetRacer oil.
Old Jan 31, 2003 | 11:03 PM
jiminok's Avatar
Now that's some serious blending CHET![img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 31, 2003 | 11:45 PM
jetjock16's Avatar
i did alot of reaserch on oil about a year ago for some various reasons but learned alot. Before that i had been a Die Hard fan of Castrol GtX, which is almost as good as any,....... the only company that was always better in the tests was Quaker state, and special brands of Valvoline race oils such as there VR1 series......... Anyway Quaker state is as good as it gets in dino oil so your set, you could run that stuff in almost any conditions and be great, if your runnin in more that an average temp of 90 degrees id go to 20w-50. Just make sure you change the stuff out about after 10 rides or 6 months, now if you want to go synthetic AMSOIL is the best product out their, the mix of additives they use including the highest amounts of zinc produce amazing results...... stick with their motorcycle specific lines to avoil friction modifiers. That is what i run, puts almost zero wear on your engine.........
bottom line is quaker state is a good choice, run ' er hard
Jetjock16
Old Jan 31, 2003 | 11:57 PM
Eaglecollector's Avatar
Been using Quakerstate for over a year now. No complaints here. I change my oil after 3 weekend rides though. May seem like thats to often. But the oil is considerably darker than it was when it went in. I do the oil filter every other oil change.
Old Feb 2, 2003 | 01:18 AM
MnTurboPaws's Avatar
...Amzoil 20-50wt summer & amzoil 10-30 winter...or Mobil 1 ..20/50 & 10-30 mobile 1 ...engine temps will be lower with these oils...been using them for years...I use it in everything I own..2000 Harley,lawn mower,snoblower, V-10 Dodge 4x4 truck,4-cylinder wood chipper, you'll never go back to dino oil...
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
hoopduerr
Jun 2, 2015 09:01 AM
