Bypassing the Reverse Rev Limiter on 2001 Raptor
Old Feb 2, 2003 | 04:07 PM
yamahasinWA's Avatar
Default Bypassing the Reverse Rev Limiter on 2001 Raptor
How do you bipass the reverse rev limiter on a 2001 Yamaha Raptor?? Which wires?? Thanks!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 19, 2003 | 09:39 PM
RepTaR660r's Avatar
the 01 raptor does not have a reverse rev limiter
Old Feb 19, 2003 | 10:09 PM
Mine does.
Old Feb 20, 2003 | 10:26 AM
tprender's Avatar
The 01 Raptor had the limiter set to high, you could do 30 mph in reverse. The 02 and 03 models are the ones that you need to bypass the rev limiter so that reverse works. I think that it is the black and white striped one under the seat. If it is the correct colored wire run a jumper wire to ground and this will take care of the rev limiter on the 02 and 03 models. You will lose the rev light when you do this.
Old Feb 27, 2003 | 02:53 PM
JoeMillionare's Avatar
FYI: REVERSE REV LIMITER
Warning: Dangerous Modification
To bypass the reverse limiter on ALL model year Raptors is to cut the GREEN/WHITE wire
near the CDI box and ground this wire that goes into the ignition. This tells the CDI that
you are in a forward gear, however the ignition will not be able to turn on the
reverse indicator light.
-Joe
(not from the TV show)
Old Feb 28, 2003 | 11:05 AM
tprender's Avatar
Thanks for getting the color of the wires corect. Ny 2 friend that have Raptors had to do the wires because of the rev limiter kicking in in reverse. On the 03 model he was not able to back up on flatground with out the limiter kicking in. One time he had to get off and push just like my 400. did I get some good milage aout of that one.
Ramman1
Jun 16, 2016 09:07 PM
house1
Aug 9, 2015 10:49 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
