buttons
Old Feb 2, 2003 | 11:25 PM
hannahj's Avatar
Default buttons
when i get a clutch kit do i need to buy buttons along with it im going to get the hpd one but sshould i go with the $90 or $155 the 90 doesnt have a helix do they really help that much
Old Feb 2, 2003 | 11:47 PM
2manytoys's Avatar
Default buttons
The helix helps with the upshift and downshift. Some people use them and some dont. It is not needed. You will probably notice more of a performance with more modded bikes. I do not use the helix on mine. I have rode TB,s with and without the helix and have noticed little gains. If I ever upgrade my clutch again I will go with a roller clutch. I am very satisfied with the $90 HPD kit. Most likely your buttons are ok because it is not an old machine. If they are worn a little you can turn them 180 degrees so the good side catches the helix.
Old Feb 3, 2003 | 07:57 AM
ftwflh's Avatar
Default buttons
All I use is a spring change and I am happy with the improvement but I just trail ride and mud ride.
Old Feb 3, 2003 | 09:05 AM
ProXPredator's Avatar
Default buttons
Like 2manytoys said, just inspect the buttons. They are not expensive to change, and if they are worn, I would suggest replacing them. If you are going to have your clutch appart, clean it up real good and change the buttons, then you don't have to worry about them again for a long time.
Old Feb 3, 2003 | 09:11 AM
elroy2's Avatar
Default buttons
I have seen buttons go out on machines less than two years old. Don't let age fool you. I change my buttons on an average of once a year if not 2 or 3 times. As for turning them around, maybe if I was in a pinch and couldn't get new ones. Other than that just buy new and replace them. Believe me, its alot cheaper than what could happen.
flyin-lowe
Dec 1, 2017 03:18 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
