How to....
Old Feb 19, 2003 | 12:09 AM
PLAYRIDER's Avatar
Default How to....
How can i strighten a bent axle on my blaster?
Old Feb 19, 2003 | 12:16 AM
OutOfControl's Avatar
Default How to....
Its easy, just go out and smack another tree. This time will take a little more finess, must hit it the right way.
Old Feb 19, 2003 | 02:18 AM
RoostItUp's Avatar
Default How to....
HAHA! Your gonna have to go buy a new axle. If you think your gonna have problems bending another I recommend buying an aftermarket one not another stock.
Old Feb 19, 2003 | 02:22 AM
CTATV's Avatar
Default How to....
very easy. you will only need a few basic tools. First of all, remove the axel from the quad. Next place it in a vice. After you have done that grab a hammer and bash the sh*t out of it untill it is a circle. Then you can go inside and order a new one. Thats the best way to straiten an axel I know. All you need is some basic tools including: vice, hammer, socket set or T bar, Credit card, Phone or computer with a connection to the internet.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 19, 2003 | 11:08 AM
AlkyBurninX's Avatar
Default How to....
CTATV, that's good!
Depends on where it is bent. Yamahas are bad about bending at the thin spot right before the hub. If it is bent here, you can put it in a vice and straighten it. If you think it is close to being straight, lay it on the ground and roll it to see if it is straight. If it is bent in the center, like my banshee's, it is hopeless.
Old Feb 19, 2003 | 12:40 PM
jcsact's Avatar
Default How to....
Some Machine Shops can try and straighten it. If it not bent to bad but it could bend again pretty easily. Your Best bet is to use CTATV's advise.
Old Feb 19, 2003 | 05:41 PM
PLAYRIDER's Avatar
Default How to....
thanks for the info.
Old Feb 19, 2003 | 05:50 PM
warrior007's Avatar
Default How to....
I have straightened the ends of axles using chains in the floor of my buddies garage (for auto frame straightening)
I chained the quad to the floor over the axle near the bend and used a floor jack to press up on the axle, takes a little patience and a few tries but if its not bent bad and on the end of the axle I would try it.
Jmuddin284
May 16, 2011 10:01 PM
THELADD
Feb 7, 2008 04:42 PM
tundraotto
Aug 11, 2006 09:20 PM
ILivSD
Mar 3, 2006 02:15 AM
ThaChad
Aug 6, 2005 04:41 PM
