need to upgrade the Rap (advice)
Old Feb 19, 2003 | 12:45 AM
ALIENRAPTORX's Avatar
Default need to upgrade the Rap (advice)
What combo should I go with on a 03 raptor with alien pipe and headers, dynojet stage II kit, and pro design kit with K&N without Airbox?12:1 with stage2 Hotcam, springs and valves, or 11:1 with stage1 ????stage2 hotcam with springs. Also should I replace the rod while i'm in there. How hard is it for someone with minimal (Very minimal) mechanical experience to do the work?
Old Feb 19, 2003 | 12:58 AM
wshrdskin's Avatar
The rod can't be replaced without splitting the cases. You have to seprate the crank to replace the rod. As for the other questions. If you go Stage 2 go 12:1 If you go Stage 1 go 11:1. JMO
The piston cam stage 1 you can do your self with some mechanical knowledge. The stage 2 with springs will require more kinowledge and valve spring compressing tool.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
