spark plugs
Old Feb 19, 2003 | 08:08 AM
miniblaster's Avatar
Default spark plugs
i was just wondering what type of plug everyone runs in there shee or anything for that matter. does it really make a difference to change to a different style plugs. right now i am running the plain old ngk plug, but want to know if any powere is to be gained by switching to a different plug?
th
mini
Old Feb 19, 2003 | 11:50 AM
AlkyBurninX's Avatar
Default spark plugs
I run NGK's BR9EIX Iridium plugs in both of my banshees. They are about 10 bucks a pop though.
You will be fine with BR9ES or BR8ES.
Another good plug that is around 6 bucks is BR8EG's. You can NOT foul these.
Old Feb 19, 2003 | 12:23 PM
ct330's Avatar
Default spark plugs
you do not need th "r" just a b8es or what ever but you dont need the "r" it cost more for the resister and you done have a true lighting system on a banshee.
Old Feb 19, 2003 | 12:29 PM
Default spark plugs
CT is right. I had forgot I was running the resistor plugs just because I have the Dyna.
Old Feb 27, 2003 | 01:17 PM
cOoLdevil's Avatar
Default spark plugs
hi can any one tell me what is the difrance. in the NGK's BR9EIX Iridium plugs and the BR8EIX Iridium plugs can theas be install to a 2003 banshee stock one .
Old Feb 27, 2003 | 02:56 PM
Default spark plugs
The number is the heat range. With NGK plugs, the lower the number, the hotter the plug. With a stock banshee, 8's are fine. I run 9's due to my ignition timing, fuel, etc.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
