reeds
Old Mar 1, 2003 | 06:25 PM
ridered62's Avatar
Default reeds
what would you recommend for me to put in my 86 250r....boyseen rad valve or vforce...thanx
Old Mar 1, 2003 | 08:16 PM
havinnoj's Avatar
Default reeds
I have used both V-force and Pyramid reeds. In my opinion, V-forces are the best. I feel as if Boysen has been pased up by the competition. They need to get back into the game. Just my 2 cents.
Old Mar 2, 2003 | 07:28 PM
tmm15's Avatar
Default reeds
I have used almost all of the reed setups. By far the best is the V-force. If you are going to purchase a used set make sure that the reed stops are the updated ones. They are usually black. The old style is bad about breaking reeds. Also run the reed stop in the setting with the least amount of tension.
Old Mar 3, 2003 | 02:38 AM
dirtgirl's Avatar
Default reeds
Between Boyesen and V-force I would choose the V-force but the Pyramid reeds will give better low-end power as well as midrange and topend power. If you are going with either the Boyesen or the V-force then it also helps to run a spacer under the reed cage... You shouldn't run it with the Pyramid reeds though.
Old Mar 4, 2003 | 06:19 PM
td250r's Avatar
Default reeds
V-Force. Second best decision I have made besides buying my 250r.
86trx250r - trinity port/polish, fmf pipe/silencer, v-force, k&n, razrs & haulers
97 warrior - stock
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
